[SOLVED] Weird Sound from PC - Link to sound
Possible hard drive failing
But also possible that something isn't quite tightened down properly. I would check that first. If your build does have a lot of fans, it might be that, or some cable is interacting with a fan i.e. better cable management is needed
Aug 11, 2020
did u opened ur CPU and located the source of sound
I think this kind of noise will be coming from your fans .....
can u please tell me which mobo, fan configuration are you using
RyzenNoob
390
27
4,790
