Question Weird static noise/Artifacts ON RX570 8GB
Mar 18, 2020
I have recently purchased Brand new XFS RX570 8GB GPU FROM A RENOWNED Local Store ,About 10 days ago,I was running my pc from 8am to 2pm for downloading just cause 3,When i tried to install the game this weird artifacts/Static noise happened to my monitor .Then restarted the pc it fixed an gain started after a while,Reinstalled the driver and adjusted the fan solved for a while,after few days i started playing metro exodus suddenly this problem happened again,what is causing this problem,?
My Specs: Intel Core I5 3470 CPU
Motherboard:Gigabyte H61M
Ram:adata 1600 Bus DDR3 8GB(4X2)
PSU:Zalman 700W
GPU:XFS RX570 8GB
Monitor, Dell 1600x900P (Don,t remember the model) .I use VGA To HDMI Converter for my monitor.
OS:Windows 10 1909
Driver:Adrenaline 20.2.2 (Tried with 19.9.1 same Problem)
Note:Recently I purchased a used gpu before the new one and while gaming same problem happened to that gpu and also pc shut down after exiting the game,Now on new GPU Same problem happening,so is it becuase of GPU
