Question Weird stuttering probably caused by monitor ?
svat
141
Hello guys i own a AOC g2590fx 144hz gsync compatible monitor and my problem is that in csgo i'm running 250fps on average, but when my fps drops to 190-170 in site im noticing lot of ghosting/tearing. Is that normal or is there possible fix? My pc is decent, i have rtx2070, ryzen 5 3600 and 16gb ram. Temps are fine. I have gsync turned off only in csgo because i was having problem with random screen blanking while i was not in gsync range and it cause me a lot of screen tearing.
thanks for any help
You might want to see if capping your frames to 140 or 160 helps you in this arena, with GSysnc enabled. Also, make sure your motherboard's BIOS is up to date, try and use DDU, reinstall your GPU drivers and then see if the latest drivers alleviates the issue.
