Problem explained below. Please let me know what you think. First I will give you my temps and other stats of all my OC attempts.
OC attempts. Stressed using dual prime 95's
Voltage is at 1.3(as reported in Speedfan and PC Wizard. I have it set at 1.325 in BIOS, showing actual of 1.3 in BIOS
E6600
eVGA 680i A1
G.skill DDR800 HZ's
eVGA 8800GTS 640mb
2700Ghz(300x9)
Program/temps(idle/load)
TAT - 35/30(cores idle) - 45/42(cores load)
Speed Fan - 41(idle CPU Temp), 53(load CPU Temp)
PC Wizard - 34/29(Cores idle) - 46/43(Cores load)
CoreTemp - 34/30(Cores idle) - 46/42(Cores load)
nvMonitor - 40(idle)/53(load)
BIOS. - 43(idle)
2835Ghz
Program/temps(idle/load) - Dual Prime 95's
TAT - 36/31(cores idle) - 46/43(cores load)
Speed Fan - 41(idle CPU Temp), 55(load CPU Temp)
PC Wizard - 34/30(Cores idle) - 47/43(Cores load)
CoreTemp - 34/30(Cores idle) - 46/43(Cores load)
nvMonitor - 40(idle)/54(load)
BIOS. - 43(idle)
2996Ghz
Program/temps(idle/load) Dual Prime 95's
TAT - 36/31(cores idle) - 47/44(cores load)
PC Wizard - 34/30(Cores idle) - 47/45(Cores load)
CoreTemp - 34/30(Cores idle) - 48/45(Cores load)
nvMonitor - 40(idle)/55(load)
BIOS. - 43(idle)
Orthos(1hour)-
Program/temps(load)
TAT - 48/44(cores load)
Speed Fan - 56(load CPU Temp)
PC Wizard -48/45(Cores load)
CoreTemp - 48/45(Cores load)
nvMonitor - 56(load)
TAT
Program/temps(load)
TAT - 53/50(cores load)
Speed Fan - 57(load CPU Temp)
PC Wizard - 53/50(Cores load)
CoreTemp - 53/50(Cores load)
Here is where the problem happened. Not sure what to think of it. Windows was running stable. Idle temps where even lower than previous testing because I stuck a big Fan in front of the PC(ambient temps are starting to warm up here). I watched the dual Prime 95's run for about 15 minutes(Never got above 54 degrees C before I left) and then went to go get some food. Came back about 20 or so minutes later and it was still running and my CPU temps in nvMonitor, SpeedFan, as well PC Wizard said 102. The PC wasn't locked up, Prime 95 was still running(no errors, ect). I shut down prime 95 and the temp stayed at 99 degrees. I turned it off and booted into BIOS and it said that I was at 40 degrees idle.
I booted back into windows at the same 3109Ghz and all my temps are idle at about 37 degrees for the CPU.
3109Ghz(345FSB)
TAT - 32/27(cores idle)
Speed Fan - 37(idle CPU Temp), 102(load CPU Temp) <-----WTF???
PC Wizard - 30/27(Cores idle)
CoreTemp - 30/25(Cores idle)
nvMonitor - 37(idle)/102(load)<-----WTF???
I would think I would have seriously damaged something if my temps really got to 102 degrees C. Especially for any length of time. But everything seems to be fine, like I said Windows wasn't even locked up. I also don't have Thermal control disable in BIOS.
I also realize that my core temps should be showing higher than my CPU temps. I am not sure why they are showing lower. I don't have core temps for speedfan because I jacking around with the offsets and I am not sure if I set them right so I didn't see a need in reporting them.
Thanks for your help.
E6600
eVGA 680i A1
G.skill DDR800 HZ's
eVGA 8800GTS 640mb
2700Ghz(300x9)
BIOS. - 43(idle)
2835Ghz
BIOS. - 43(idle)
2996Ghz
BIOS. - 43(idle)
Orthos(1hour)-
Program/temps(load)
TAT
Program/temps(load)
3109Ghz(345FSB)
