hello i have an fx 8350 with stock fan and been trying to overclock(wthout increasing voltage) for a while but i get really high temps, 65+ ºC in just seconds with Prime95. i tried to reduce the voltage by 0.08v and i was still getting really high temps on prime95 and CPU-Z stress test.
i was thinking about buying a better cooler but i just noticed that on idle i am getting around 18 ºC which i think is pretty low, is it possible that msi afterburner isn't reading the temp properly?
i tried HWMonitor but sometimes it gets stuck and doesn't update the temps
temperature while gaming is fine even in cpu intensive games and low resolution
i also noticed those weird spikes where the cpu temp increases like 5 and then comes down instantly
EDIT: Msi Afterburner and HWMonitor report same high temps
i already changed thermal paste
my pc case is opened
1 minute of Prime-95: https://imgur.com/a/R2HanLp
my CPU: https://imgur.com/a/DPWPlnf
Motherboard: Asus sabertooth 990fx r2.0
