Weird water stains on my monitor.
SVZA
Commendable
May 16, 2016
6
Hi guys
Please check the images, as I am not sure what are the marks on my monitor.
http://imgur.com/iiBmPRe
http://imgur.com/f9cwPGp
http://imgur.com/dwZIHmI
http://imgur.com/0Q5aNJ1
http://imgur.com/Y4wskn3
http://imgur.com/WJbC78c
It looks like water trapped behind the cover on my monitor and the LCD screen, but when I touch it, it is not moving.
It started as a small 2" size mark, and in 4 months it spread to almost half of the screen.
Please let me know your thoughts about it, and possible solution.
Thanks
New Images below:
Fixing monitor panels is only reasonable under warranty. If your monitor isn't under warranty the only fix is buy a new one. Maybe use that one as a securtiy cam monitor as the problem may not show in black in white. You could try lower resolution but still may be to visable.
Ouch. I don't think there's much of a 'solution' to be had. You're either looking at replacing the panel, or just replacing the monitor.
I would assume the new monitor route would be in the same ballpark price-wise, and a lot less hassle.
