WEP vs WPA in terms of speed
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: alt.internet.wireless (More info?)
Hi,
I am currently using 64-bit WEP and I clocked just north of 3000 kbps on the
CNet Bandwidth Meter (my ISP is Comcast in San Francisco).
I wonder how much faster this connection would be if I used WPA compression
instead.
Also, if I am using the generic Windows (I have XP Professional) drivers for
my Wi-fi NIC (Linksys WPC-11), for networks that have other types of
compression, I still get the message that the selected network has WEP
compression when I click the 'View Available Wireless Networks' option. Any
ideas?
Anuj
PS - Regarding my earlier problem (thread - 'I have an interesting
problem'), it turns out that Windows XP does not accept a password for an
encrypted network. It will only accept a key.
The 3Mbit/s download speed is about as fast as it gets with cable modems.
802.11b can handle up to 11Mbit/s (although, real world numbers are about
half that) and 802.11g can handle up to 54Mbit/s. WEP and WPA encryption do
add a bit of overhead in terms of calculations needed to encrypt/decrypt but
do not have major impacts on performance.
Your main bottleneck is the cable modem (although, 3Mbit/s is much faster
than most DSL lines). An upgrade to 802.11g would only make sense if you
want to set up a LAN. Using either WEP or WPA will not slow things down
noticeably and you should use one of them.
-Yves
"Schizoid Man" <schiz@sf.com> wrote in message
news:cmdrbh$e06$1@geraldo.cc.utexas.edu...
> Hi,
> the
> compression
> instead.
> for
> Any
> ideas?
> Anuj
