[SOLVED] What’s wrong with my ASRock AB350M Pro4
Drake Atlas
17
Hi guys!
So I’ve recently just built a gaming Pc with a Ryzen 3 2200G RX570 and 2x8 GB DDR4 21333mzh and the MB is AB350M Pro4 but the rx 570 just wont be recognised by the MB so when I plug in the DVI to the RX 570 the display won’t show. However if I plug the DVI cable into the MB it works fine. I’ve tried using a HDMI Cable not still nothing works?
Need some help with this! And thanks for your time
DL CPUZ and it will tell you what BIOS you are on...or you could check within your BIOS. On ASRock site are available newer BIOS that optimize performance for newer cpu, since your chipset (350) was designed for 1xxx CPU. The AMD All in One driver is a driver pack that has both chipset drivers as well as graphics drivers. Read up.
Mate I’ve literally have no clue what that’s about
Let me try I’ll get back to you Thx for the help
