Question What adapter do I need to convert the 5v 3-pin to 12v 4-pin ?
Jun 25, 2024
5
So i got this Hub along with my case but it comes with a 5v 3-pin Argb connector while my motherboard only supports the 12v 4-pin connector. So i was wondering if there was any type of adapter out there that i could plug into the hub and get a 12v 4-pin input connector into the motherboard.
So i got this Hub along with my case but it comes with a 5v 3 pin Argb connector while my motherboard only supports the 12v 4pin connector so i was wondering if there was any type of adapter out there that i could plug into the hub and get a 12v 4pin input connecter into the motherboard.
What motherboard? What pc case?
If motherboard has no 5V aARGB connector, then you can not connect 12V RGB hub to it.
Your case/argb hub probably supports several rgb light modes without using connection to motherboard.
Those are changeable by using buttons on pc case.
Or alternatively you can purchase 12V RGB hub and replace all your fans to 12V RGB models.
I have MSI B450 Gaming Plus with a Ice Master Frosty Black Case and the hub also supports
12v 4-pin fans
Bruh i have Alzheimer's i connected the reset switch to it to change the lighting but i forgot. So any chance i can adjust the fan curve with the hub?
