HI there, i have bought this list of pc parts and put them together :
sahara p35 case
Tomahawk B350 Board
Dark Rock pro 3 aircooler Cooler
Ryzen 5 1600 CPU
Now in the case i have 3x120mm fans at the front pulling cold air in and 1 fan at the back pushing air out, i also have the option to install 3x 120mm fans on the shroud that covers the psu and the hard drives as seen in this picture :
Now i cant install the middle one at the bottom cos of the usb 3.0 cable as it sticks out from the mother board to much , so i installed another 2 , but the problem is they suck hot air out from the bottom and dont pull cold in , i cant change the orientation of the fans as in the middle there is a dome. so after all this info i have 2 questions.
Is it safe for the fans over the psu and the 2 HDD to push the hot air out from the bottom out, and as i have the dark rock pro 3 if i was to change to the max AIO i can which is a 280mm say the NZXT Kraken X62 big or go home am i going to see a change in temps as at the moment i run a max playing 7 Days To Die at 55oC on the CPU and my GPU which is a EVGA 1070 at 67oC
Any and all info is very much welcome
And thanks.
sahara p35 case
Tomahawk B350 Board
Ryzen 5 1600 CPU
And thanks.
