My DDR3 RAM became damaged, so I decided it was time to get a new motherboard and upgrade to DDR4. I know that even with this upgrade I'm still out of date, but I want to stick with LGA1151 for a while longer, as my i7 6700K has been doing fine.
Well, I'm now two months deep into an absurd adventure trying to build a working system.
I started with this build:
Motherboard: ASUS PRIME Z390M-PLUS
CPU: Intel i7-6700K
RAM: 2x 8GB Corsair Vengeance Pro DDR4
CPU cooler: Corsair H100i ELITE CAPELLIX WHITE AIO Cooler
Case fans: 3 Corsair iCue SP120 case fans
PSU: EVGA 500W
I also have an Nvidia 1660, and I've tried booting both with it and without it.
For the monitor, I've tried with my Samsung TV and an old DVI monitor, both devices recognise that something is connected but receive no data.
The board seems to attempt to power up three times. On the third try the fans and lights would remain on, but it would send nothing to the monitor. Video demonstration here:
View: https://www.youtube.com/watch?v=fFVr4Yjp2mI
I sent this video to the aftermarket sellers in China who sold it to me, and they had an engineer look at it - no advice. I also had a local PC repair shop look at it and try swapping out some components, they also couldn't definitively diagnose the issue.
I thought the issue was that some of the LGA1151 pins had been damaged when I was installing the motherboard (I did something stupid with the CPU cooler out of laziness) even though I and the repair shop guys had managed to carefully move the pins back into position. However, I have tried two other motherboards (treating them with more respect and care) and the problem still seems to be there. In fact, at this point I've replaced every part of the computer except for the case, and nothing changes!
Motherboard: I've tried replacing with ASUS Prime B360M-A and ASrock B365M Pro4. Both ASUS motherboards behave the exact same way, which leads me to think that they are responding in an expected manner to some other issue. The ASrock seems to switch on for one second and then immediately shuts off again.
CPU: I've tried my old i3-6100, no change
RAM: Fanxiana 2 x 8GB DDR4
CPU cooler: Noctua LH-9i
PSU: Corsair RMx 850x
Again, I've tried with and without the video card. The repair shop said the Intel i7 does not have onboard graphics, but I've seen people reporting the opposite, and I'm sure I remember using onboard graphics on the last motherboard.
The only reasonable explanation is user error - I must be connecting something incorrectly, though you'd think the repair shop would have noticed if that was the case. Based on the video linked above, can you see anything that's not connected correctly? What embarrassingly obvious step might I have forgotten?
Note: the problem that triggered the upgrade did not present this way. The computer would POST and then display an error message regarding the memory. I ran a memory check and there were <Mod Edit>-tonnes of errors. It seems unlikely that the two problems are connected, but at this point I'm open to any theories.
Edit: also, the repair shop fitted a motherboard speaker as I lost mine at some point. I got no beeps, unless I tried turning it on without RAM. Today the speaker broke, so I don't have any beep indicators regarding the change of PSU or cooler - fans and lights do the same thing that they were doing before though, so I don't think anything has changed.
CPU: Intel i7-6700K
PSU: EVGA 500W
