What and how should I pick the new parts for my pc
TRG_SN1P3R
I have recently decided that I need a new Computer BAD. I have a budget of $600ish. I have already decided to go AMD simply because they are cheaper and from what I have read they aren't that bad. I am a avid game and do play a lot of such as War thunder and World of tank.
I do some how manage to get a sorta stable 30 fps but that only because the graphics are on low.
I would like to be able to play Bf4 or Bf3 on at least med settings if possible.
Thank you for any answers to this post.
Current specs:
Intel Pentium dual e2180 at 2ghz
Four Gigs of ddr2 mem at 677
Asus Geforce 610 2gb of ddr3 mem
MS-7525 motherboard
Thanks For the builds Mephikun. I would like others input too, I would like to get the best feel of what I can get for my budget.
No problem.
Another route you can take (which isn't the most ideal) would be an APU build.
Here's an APU build (I would recommend swapping out the motherboard for this one as the one listed seems to have some issues: http://www.newegg.com/Product/Product.aspx?Item=N82E16813132080 )
http://pcpartpicker.com/p/3aBpV
Would give you a little extra headroom for something like a Samsung 840 EVO 120 GB SSD and if you wanted, although you probably won't get the performance of the other builds even doing this, you could get a Radeon R7 240/250 for Dual Graphics with the A10.
Good luck.
