What Antenna Port To Use?
djelric
Hi All,
I have a TM-AC1900 and I was wanting to attach a new 5ghz outdoor antenna to it. My problem is that I don't know what stock antenna to remove and connect the new one to as there are 3 antenna's on the router.
I've tried some googling on this but my wording may be off as I can't find anything about my particular situation.
Thanks for any help you can toss my way.
It shouldn't matter. That is a three stream router. Each antenna is connected independently. I assume you are trying to connect to a public WIFI as input. I would recommend a separate outdoor wireless bridge for that job, but that is just my opinion.
