what are best case fans right now?
cheechx310
147
what are the best case fans right now?i don't care about noise level i just care about the effectiveness of the fan. here is my build PCPartPicker part list / Price breakdown by merchant
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($215.00 @ Amazon)
Motherboard: ASRock Fatal1ty Z97 Killer ATX LGA1150 Motherboard ($100.98 @ Newegg)
Memory: G.Skill Trident X Series 8GB (2 x 4GB) DDR3-2400 Memory ($75.89 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.89 @ OutletPC)
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX 2.0 Video Card ($323.98 @ Newegg)
Case: Corsair SPEC-01 RED ATX Mid Tower Case ($34.98 @ NCIX US)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($99.99 @ Micro Center)
Optical Drive: Asus DRW-24F1ST DVD/CD Writer ($17.88 @ OutletPC)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit) ($89.98 @ OutletPC)
Monitor: Asus VG248QE 144Hz 24.0" Monitor ($264.99 @ B&H)
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter ($36.79 @ OutletPC)
Total: $1310.35
Generated by PCPartPicker 2015-02-23 10:47 EST-0500
i would choose the corsair af series or the sp series GET THE SP SERIES IF YOU HAVE HDD CAGES. if u dont then AF is the way you wanna go. some people might say that phantek fans are better. but i have had both and the corsair AF pushes out more air then the phantek. just my thoughts im sure somone here will correct me. OH also if u dont want ur fans to look good look at nocutas fans they are amazing but look like shit litterly
I've always considered Noctua ugly and expensive, then I bought one for my H60. Now I'm a Noctua convert, upgraded from the NF-F12 to an NF-F12 iPPC-3000, I tried it with the settings for the NF-F12 and decided it was too loud @ 100%, cut it to 70 and it cools better than the regular F12 and is only just a bit louder. And the new Industrial ones are more pleasant on the eyes than the old ones.
+1 for Noctua
Are the Noctua fans ugly... yes. Does it matter... heck no. Because they work! And you never see your case fans, so who cares.
I have a couple dozen scattered in machines around the house and not a single one has ever failed or made a peep of noise not normally attributed to a fan. They are worth every penny.
