What are decent temps for i7 7700k?
randomname6969
124
I overclocked my i7 7700k to 4.8 ghz with a cryorig h7 universal as a cooler. The max temps i saw were around 83c on one core and 82c and 81c on the other 3 cores. Is this safe temps?
i used the one on cpu-z. I dont know if its the most reliable program to get temps tho
Hmmm I've played with it before but I dont' remember what temps it gave me. I know I had H7 with my 7700K and at 4.5GHz I would run Prime95 v26.6 Small FFT's and get 81-86C depending on how long I let it run.
If you get consistent temps over 80C in regular use I would down clock a bit.
The main thing is, in regular use, the cpu will stay around low to mid 70's. When i used the prime95 small fft's test, the default test used 8 torture tests and that spiked my cpu up to mid 90's to 100
from what i've seen though, the most it'll do is spike up to 85-90C for a split second every once in a while. Doesnt seem like too big of a deal.
