I know this is late in the year but I finally saved enough to build my first PC capable of gaming.
I decided to test its temps just to see how to stock cooler performed. First I downloaded HWMonitor and tested it during skyrim special edition (played for abut 20 minutes) got about 45 degrees Celsius.
Then just to double check I downloaded Aida64. With CPU and Cache selected (over an hour of testing) I got just over 50 degrees Celsius
I then selected FPU as well and after 15minutes I got just about 53celsius.
So my question here is are these normal temps for the i5-6500 using the stock cooler with full load?
I would have expected much higher with the Stock Cooler with at least 60 degrees Celsius.
Is my CPU Normal or is something wrong with it? Is it freakishly good?
Room Temp (23-25 Degrees Celsius)
I am using a
i5-6500 (Stock Cooler)
Gigabyte Windforce OC GTX 1060 6GB
Gigabyte GA-H170-HD3 Motherboard
16GB Ram
Fractal Design 550W Edison PSU
I am using a
16GB Ram
