What are the best performing and most quiet fans for a 120mm radiator?
Basically I would like everyone's opinion on the best PWM fans for a push pull setup on a 120mm radiator. The fans will be connected via a splitter to the CPU fan header and run on my custom CPU heat index fan control profile.
I have only a single fan in pull right now (radiator is on the rear exhaust fan slot). This is the stock fan for a Coolermaster Hyper T4 and it is LOUD when it gets above 75%. It does move decent air though.
I want everyone's input as to the best performance and most quiet fans for this push-pull setup. I DO NOT want to pay $25 a fan. I know there are some gems out there like the Silverstone ap-121.
Please let me know what you think.
TL;DR: What fans are the best balance of noise/performance/price for push pull on a 120mm radiator?
EDIT: I was about go to buy the Cougars but basically everyone said they whine at anything except full speed.
Sanyo Denki (sp?) and Delta are highly regarded, but are expensive.
Koolance makes some very high CFM/Static pressure fans with a decent noise rating and price. They're the best I've seen on paper, but I havent tried them yet. Some models draw a ton of power though (~2amps), definitely wouldn't put those on the mobo. I'd try one of these 2:
http://koolance.com/fan-120x25mm-108cfm
http://koolance.com/fan-120x38mm-116cfm
Silverstones high performance 120mm fan has impressive numbers, as does their 140mm fan with 120mm mounts (http://www.silverstonetek.com/product.php?scase=c_140&pid=366&area=en)
30dba is fine. But none of the fans you linked are PWM fans. those are all 3-pin, and the silverstone will not fit in my application even though it has 120mm mounts.
I am talking about more mainstream fans like Corsair sp120, Rosewill Hyperborea, etc.
to change the subject a little, what are the best high performance fans regardless of the noise they create, i am only interested in the performance side.
i dont mind the noise as it is rather soothing, to clear that point up.
i have wanted to go with the Corsairs SP120 PWM High Performance Fans but i have heard that there are now better fans on the market.
