[SOLVED] What are the recommended parts with 1070ti?
kristopherius
Commendable
Jul 1, 2017
7
Last year november I bought myself a 1070 Ti for my slightly older gaming system (16GB DDR3 Unsure about the Mhz/ i7 4770k OC/ Gigabyte H87-HD3/SSD for my windows/ and). Over the course of this year I have noticed that I might be bottlenecking my performance with my other parts. I need help finding the right other parts for the best equalized performance with the 1070Ti.
I wouldn't say your bottlenecking your 1070ti, if you upgraded to a better GPU you would get better FPS, if you upgrade to a better CPU you will get better FPS. What resolution are you playing at?
If you want to upgrade your CPU I would go with the 3600/3600x, that would require a new mobo and new ram. Lowest cost would probably be $350, that would be with bottom end parts though.
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($198.90 @ OutletPC)
Motherboard: MSI B450 TOMAHAWK ATX AM4 Motherboard ($114.99 @ Best Buy)
Memory: G.Skill Sniper X 16 GB (2 x 8 GB) DDR4-3600 Memory ($79.99 @ Newegg)
Total: $393.88
Prices include shipping...
kristopherius
Commendable
Jul 1, 2017
7
i have a similar setup and i don't notice any bottlenecking (i7 4790 and 1070) - what games do you play?
Witcher 3 at medium high struggles to get 60fps. Pubg at max hovers at 70 but drops often. I tried Assasin Creed Odyssey and then it averages 50fps at medium settings with a lot of drops. MORDHAU gets only around 55-60 at low without ragdolls or 40 with ragdolls, which is suprisingly low, but i dont know which pc part helps best with calculating all the ragdoling bodies.
edit1: also i forgot to mention gta5 never gets above 60 whatever settings i have
kristopherius
Commendable
Jul 1, 2017
7
Playing at 1080p. Do you know what could fit well with the 3600/3600x Ram and MoBo wise ? (Not bottom end necessarily)
hftvhftv
Ambassador
Total: $393.88
Generated by PCPartPicker 2019-08-06 11:59 EDT-0400
This is what I'd upgrade to if you have the cash, the 4770 is five years old, so it's getting a little long in the tooth.
kristopherius
Commendable
Jul 1, 2017
7
Total: $393.88
That certainly looks within the budget, Thanks a lot!
