Question What are your thoughts on my first pc build?
Aug 29, 2022
6
This build is a rough first draft for a pc that I'm planning to build.
Built for playing modern mmorpg games like final fantasy 14 on 1080p 144hz max settings
https://pcpartpicker.com/list/gtZFxs
CPU: AMD Ryzen 5 5600 - 200$ | GPU: XFX Speedster Radeon RX 6600 - 310$ | Motherboard: MSI B550M PRO-VDH - 160$ | RAM: ADATA 16 GB - 80$ | SSD: Verbatim Vi550 SATA III 512gb - 50$ | PSU: SilverStone SST-SX500-LG v 2.0 500gb - 160$ | CPU FAN: Thermaltake UX 100 - 16$ | Screen: MSI Optix G272 - 330$ | Case: Fractal Design Define Mini C - 110$
Total cost: 1416$
Are any parts here overpriced or overkill? What are your thoughts on this build?
I live in Europe btw.
2) Would it be a good idea to buy a standard atx mobo with many pcie slots and a ryzen 7000 cpu , so then I upgrade in the far future I won't need to spend on a new mobo and cpu and this way save money?
Thank you for your feedback, I appreciate it a ton :)
Reactions: Why_Me
What is your budget? 1,400 USD? (Let me put together some parts at this budget and see what I can come up with)
General Thoughts
-5600g is an APU which means it includes integrated graphics, since you have a GPU, its not needed, stick with just a non G processor
-5600g, stock cooler is fine
- In RPGs, low resolution, high refresh is not really what people shoot for.
-Lets see if we can get you into 1440p for around the same budget
-If not, CPUs really push FPS at 1080p, you might beef up your processor.
Reactions: Sen.Armstrong
Here is what I could do for $1400.
Really good bang for the buck. Some compromises on PCIE Gen4, but that isn't really needed for gaming.
PCPartPicker Part List
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor ($193.42 @ Newegg)
Motherboard: MSI B450 Gaming Plus MAX ATX AM4 Motherboard ($99.99 @ Amazon)
Memory: G.Skill Aegis 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory ($49.99 @ Newegg)
Storage: Intel 660p 1.02 TB M.2-2280 NVME Solid State Drive ($69.98 @ Amazon)
Video Card: ASRock Radeon RX 6800 XT 16 GB Phantom Gaming D OC Video Card ($559.99 @ Newegg)
Case: Phanteks Eclipse P300A Mesh ATX Mid Tower Case ($69.99 @ Newegg)
Power Supply: Corsair RMx (2021) 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($134.99 @ Amazon)
Monitor: Asus TUF Gaming VG27AQ 27.0" 2560x1440 165 Hz Monitor ($279.00 @ Amazon)
Total: $1457.35
Generated by PCPartPicker 2022-09-25 00:15 EDT-0400
Where? You can in the pcpartpicker change country at the righthand top side for more to the point list.
Think quite a few things i would change, like cpu /motherboard and would with 1080p go for something like 24" if sitting quite close to it. With 27" you might be able to see the pixels.
Wonder if the monitor in this list is new, but if so seems a good choice, if not new look further,
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor (€157.99 @ Amazon Deutschland)
CPU Cooler: ARCTIC Freezer 34 eSports DUO CPU Cooler (€39.98 @ Aquatuning)
Motherboard: Asus ROG STRIX B550-A GAMING ATX AM4 Motherboard (€147.90 @ Alza)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory (€54.90 @ Alternate)
Storage: KIOXIA EXCERIA G2 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive (€71.99 @ Mindfactory)
Video Card: XFX Speedster SWFT 210 Radeon RX 6600 XT 8 GB Video Card (€354.00 @ Amazon Deutschland)
Case: SilentiumPC Regnum RG6V TG ATX Mid Tower Case (€76.89 @ Alternate)
Power Supply: Corsair RM650x (2021) 650 W 80+ Gold Certified Fully Modular ATX Power Supply (€80.90 @ Alza)
Operating System: Microsoft Windows 10 Home OEM - DVD 64-bit
Monitor: ViewSonic XG2530 25.0" 1920 x 1080 240 Hz Monitor (€107.28 @ Amazon Deutschland)
Total: €1091.83
Generated by PCPartPicker 2022-09-26 15:33 CEST+0200
Since Europe started with Germany as point of reference.
Reactions: RodroX
1. Generally, when building from scratch, always buy the newest/most up-to-date parts that you can afford now, which should make the next required upgrade a little further down the road... hopefully you can spring for something better than the 5600/6600 combo....which is getting a little "long in the tooth" at this point in time 😀
2. I would also suggest you budget for a large storage drive (2-4TB if SSD, or 6-12TB if a spinner) to store your games one, and keep the 512gb for your OS & primary apps
3. Although you can use any size case, ATX cases are generally roomier inside, making them easier to build in, route & connect cables, swap parts in & out, and establish sufficient/proper airflow etc.
This can be a factor for a gaming rig like you want, with the physical sizes & heat output of current & upcoming GPU's (& PSU's) seemingly increasing to really high levels...
4. I did not see any case fans listed in your parts summary, even though most cases come with 2-3 so-so factory units, you will most likely want more/better than them for a gaming rig, so you should also budget some $$ for them (~$80-100)
Good luck with your build 😀
Total cost: 1416$
Whatever you do (you have very nice suggestions from other members in the thread), never buy a PSU that have 500 gigabits on its description ("PSU: SilverStone SST-SX500-LG v 2.0 500gb - 160$).
That there alone shows you that the seller have not even the smallest clue of what its selling
According to google, $1400 USD is equal to 1456 Euro.
CPU: AMD Ryzen 5 5600G 3.9 GHz 6-Core Processor (€157.99 @ Amazon Deutschland)
CPU Cooler: Deepcool AK400 66.47 CFM CPU Cooler (€35.90 @ Alza)
Motherboard: Gigabyte B550M AORUS ELITE Micro ATX AM4 Motherboard (€114.75 @ Computeruniverse)
Memory: Kingston FURY Beast 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory (€96.89 @ Alternate)
Storage: Gigabyte AORUS Gen4 7000s 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (€95.00 @ Amazon Deutschland)
Video Card: PowerColor Fighter Radeon RX 6700 XT 12 GB Video Card (€469.00 @ Mindfactory)
Case: Deepcool MATREXX 40 3FS MicroATX Mid Tower Case (€66.14 @ Amazon Deutschland)
Power Supply: SeaSonic FOCUS GX 750 W 80+ Gold Certified Fully Modular ATX Power Supply (€84.90 @ Amazon Deutschland)
Operating System: Microsoft Windows 10 Home OEM - DVD 64-bit (€111.69 @ Mindfactory)
Monitor: Gigabyte G27QC A 27.0" 2560 x 1440 165 Hz Curved Monitor (€219.90 @ notebooksbilliger.de)
Total: €1452.16
Generated by PCPartPicker 2022-09-26 19:59 CEST+0200
Did you click the link in the partslist? That "gb" is just a fault from the OP.
