What cabinet for this rig? Sorry for putting this in the wrong forum-section, don't know where else to put it.
Dekb97
72
Hello TH. First off, apologize for the wrong section. However, I need to buy a new cabinet/case for this setup:
Intel Cor i7 4770K
Zotac GeForce GTX 770 2GB
Samsung 840 EVO MZ-7TE120 120GB
MSI Z87-G45
Kingston HyperX Predator 2x4GB
Seagate Constellation 7200 ST9500530NS 500GB
I want it to be a really great cooling cabinet. Besides that, at some point in the future, I'm going to watercool.
- Just another question before getting this rig: Would all the components run good together? Would it be a overall good set-up? Thank you on forehand, people.
Fractal Design Arc Midi R2
http://www.newegg.com/Product/Product.aspx?Item=N82E16811352031
Cooling system
•Front: 2 - 120/140mm fans (included is one hydraulic bearing 140mm Silent Series R2 fan, 1000 RPM speed)
•Rear: 1 - 120/140mm fan (included is a hydraulic bearing 140mm Silent Series R2 fan, 1000 RPM speed)
•Top: 3 - 120/140mm fans (included is one hydraulic bearing 140mm Silent Series R2 fan, 1000 RPM speed)
•Bottom: 1 - 120/140mm fan (not included)
•Fan controller: 1 - Integrated fan controller for up to 3 fans (included)
•Water cooling compatibility: ◦Front – 240 mm radiators (thick and slim) when HDD cages are repositioned or removed
◦Top – 240 mm radiators (thick and slim)
◦Bottom – 120mm radiators
◦Rear – 120mm radiators
I have the R2 it is a great case.
ATX, Micro ATX, Mini ITX motherboard compatibility
Your build would fit no problem.
The case is big for a mid tower.
9.06" x 18.11" x 20.28" (WxHxL)
2 USB 3.0 front ports.
The rest are on your mobo.
