I am completely stumped as to what do to, none of the vga cables I have work, see the image here - Imgur: The magic of the Internet
Here's your blue one: https://www.amazon.com/Serial-Adapt...ocphy=9052267&hvtargid=pla-397003917010&psc=1
Can't find the right printer cable converter at the moment.
its a GIGABYTE GA-EP41-US3L Motherboard, would a USB to Serial Adapter allow it to connect to my monitor?
which graphics card would be ideal?As stated above, the motherboard has no built-in graphics output of any kind and you cannot get any graphics here without a graphics card which needs to be installed in the PCI-e slot. The graphics card will have display outputs which can then either be used directly or with a converter to VGA, depending on the exact model you get.
Correction. Not only matrix printers, but basically all printers, including good laser ones, till mid-90ies had LPT ports 😉 Then USB as superior solution kicked out LPT in next few years, yes. Good riddance BTW.Yup, that's a very old DB-25 port. If you're trying to hook up a dreadful old dot matrix printer, you're in luck. Anything else, not so much. USB quickly killed this off in the late 90s.
OP, GIGABYTE GA-EP41-US3L motherboard does not have built-in video output. It require separate GPU card.
My mutual understanding hereIn fairness, it's been a while and I'm suffering from middle-aged senility!
