What cable do I put in my 144hz monitor
galacticsithgt
15
Ok, so recently I am getting a new setup and also a new monitor
So I have been researching about it and what cable to use in the monitor to the graphics card
I really know what cable to use but I am asking what cable do I use since my graphics card has only only DVI Port.
Will I use Display Port to DVI Cable? or anything else since my monitor doesnt have gsync or free sync. And also I will be buying two monitors of the same model and brand that is why I am asking you guys and both monitors have DVI Cable that means two DVI Cables right? Since my graphics card has only one DVI Port will I use Display Port to DVI Cable?
Another Question:If I use both DVI Cable and Display Port Cable and put both in my monitor to my graphics card will I have better performance?
Or no?
Graphics Card:https://www.amazon.com/gp/product/B06X3QRQJR/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1
Monitor:https://www.amazon.com/VG248QE-1920x1080-144Hz-Gaming-Monitor/dp/B00B2HH7G0/ref=sr_1_1?s=electronics&ie=UTF8&qid=1504101422&sr=1-1&keywords=asus+24+inch+monitor+144hz
I have the Asus vg248qe, same as link in your original post. Had it almost 4 yrs now.
That should be fine. I have 3 displays plugged into my 980ti. The Asus, an ultrawide LG and 4k tv.
so having both dvi and displayport cable on your monitor will it have a better performance?
and also what kind of cable is it advisable to use in this kind of monitor dvi-d or display port cable?
so if i have two monitors and two of them comes with a dvi-d cable and i use the dvi-d on the first monitor (main) and the second monitor i use display port cable and plug it to the display port in my graphics card is it ok?
