Hello, I'm going to get the acer VG248QE 144hz monitor:
https://www.amazon.com/VG248QE-1920x1080-144Hz-Gaming-Monitor/product-reviews/B00B2HH7G0/ref=cm_cr_dp_d_srvw_btm?ie=UTF8&reviewerType=all_reviews&sortBy=recent#R389H954S2G31R
However, I read some reviews and it said it doesn't come with a cable out of the box, and it also said to use a display port cable or a DVI dual link cable, so which one should I use? My gpu is gtx 1070ti by the way. If you also happen to know a good one that is cheap too, it would really help if you linked it. Thanks!
