What cables am i going to need for my build?
HarkenVex
So, im starting a new high end build with a custom loop and custom sleeved cables etc and i just want to make sure I buy all the correct cables. My build is as follows
CPU - Intel i7 7800X
Motherboard - Asus Strix X299-E Gaming
GPU - GeForce GTX 1080Ti ROG Strix
RAM - Corsair Vengeance RGB 32GB
Storage - Seagate Barracuda 4TB HDD
Samsung 850 EVO Pro 500GB SSD
PSU - BeQuiet Dark Power Pro 11 750w 80+ Platinum
Case - NZXT Noctis 450 ROG Edition
Case Fan - Corsair Air Series AF12 x1
And Custom Loop components
EK-CoolStream PE 240 (Dual) x2
EK-XTOP Revo D5 PWM - (incl. sleeved pump) x1
EK-RES X3 110 x1
EK-Supremacy EVO X99 - Nickel x1
EK-FC1080 GTX Ti Strix - Nickel x1
EK-FC1080 GTX Ti Strix Backplate - Black x1
EK-HD Tube 10/12mm 500mm (2 pcs) x3
EK-HDC Fitting 12mm G1/4 - Black x12
EK-CryoFuel Blood Red Concentrate 100 ml x2
EK-ATX Bridging Plug (24 pin) x1
EK-Cable Y-Splitter 2-Fan PWM (10cm) x2
Corsair Air Series AF12 x4
I understand that there may e too much information here, but i'd rather give too much than not enough. So what I need to know is, what cables am I going to have to get custom sleeves for?
Thanks for all your help
The cables that should be on the PSU already are the 20+4 pin motherboard connector and the 4 pin CPU connector. You will need two 8 pin connectors for the graphics card and two SATA power cables for the hard drive and SSD. You will also need two SATA data cables for the hard drive and SSD and these components should already have cables: fan power cables and fan controller cables, case lighting including header led's like power and HDD read, power and reset buttons, not sure about water pump power, never did water cooling before. Apart from that, you should have all you need unless you don't have an a/c adaptor to power the power supply.
