A AlyssaD Honorable Nov 25, 2013 25 0 10,530 Oct 3, 2014 #1 I have two Samsung S24D390HL (HDMI x1, VGA x1) and a 7970 which comes with DVI x2, mini DisplayPort x2 and a HDMI.
Solution geofelt Oct 3, 2014 HDMI is a digital connection and that is preferred, it will give you better image quality than vga. Connect one monitor fia a hdmi to hdmi cable. For the other monitor, look for a dvi to hdmi cable or a display port to hdmi cable.
Drew010 Honorable May 11, 2013 1,150 0 11,660 Oct 3, 2014 #2 You'll need 2 HDMI cables, and one either mini DP or DVI to HDMI adapter. Upvote 0 Downvote
hunter315 Champion May 12, 2009 10,651 3 51,960 Oct 3, 2014 #3 Use 1 HDMI-HDMI cable and 1 DVI-HDMI cable, that way you never actually convert the video signal. Upvote 0 Downvote
geofelt Titan Oct 9, 2006 56,060 4,859 174,240 Oct 3, 2014 Solution #4 HDMI is a digital connection and that is preferred, it will give you better image quality than vga. Connect one monitor fia a hdmi to hdmi cable. For the other monitor, look for a dvi to hdmi cable or a display port to hdmi cable. Upvote 0 Downvote Solution
A AlyssaD Honorable Nov 25, 2013 25 0 10,530 Oct 3, 2014 #5 Alright. Thank you for the help! Upvote 0 Downvote
