What cables do I need for my graphics card?
lanskies
Commendable
Dec 14, 2016
OKay, so I have a bit of a conundrum. I can't find any of the cables that came with either my power supply or my graphics card and I can't connect the graphics card to power. I need to buy the cables asap.
My power supply is the EVGA SuperNOVA 850 G2: http://www.evga.com/Products/Product.aspx?pn=220-G2-0850-XR
and the graphics card is the Msi GeForce GTX 980 gaming 4g: https://us.msi.com/Graphics-card/GTX-980-GAMING-4G.html#hero-specification
The only spaces left on the power supply say either sata or vga, so I'm not even sure which one i'm supposed to plug this into. Plus the graphics card is 2 8pins.
Am I supposed to go from the 2 male 8 pin cables to the vga slots or to another slot. and is there even such thing as a 8pin male to 8 pin male cables?
You need something like this, that is supported by your psu (which these are).
https://www.amazon.com/EVGA-Additional-Individually-Sleeved-100-CW-1600-B9/dp/B01K9EXZEO/ref=sr_1_1?ie=UTF8&qid=1481758449&sr=8-1&keywords=EVGA+SuperNOVA+G2+vga
look at the vga cables.
It doesn't have anything connected there, but i also don't have those cables. So what exactly am i looking up on amazon to get the right cables? just 2 8pin to 8pin? the power supply has the vga ports that look like they're female. and the graphics cards are also female... so is it two male cords? idk. I have a pcie 8 pin to dual 8(6+2) pin but it wouldn't go in...
