S SnaKeSisNG Commendable Aug 3, 2016 35 0 1,540 Aug 31, 2016 #1 I have never built a computer before and I want to get sleeved extensions, so what extensions do I need? My rig: http://ca.pcpartpicker.com/user/NnjaGodzilla/saved/68rxrH
Solution geofelt Aug 31, 2016 You motherboard will come with a couple of sata cables. With a bottom mounted psu, you might want a 4/8 pin cpu power extension to avoid stretching over the motherboard.
N NextGear Commendable Jul 20, 2016 194 0 1,760 Aug 31, 2016 #2 SnakeSisNG, none, your PSU should have everything you need. Unless you want to go with a custom theme. Upvote 0 Downvote
geofelt Titan Oct 9, 2006 56,060 4,858 174,240 Aug 31, 2016 Solution #3 You motherboard will come with a couple of sata cables. With a bottom mounted psu, you might want a 4/8 pin cpu power extension to avoid stretching over the motherboard. Upvote 0 Downvote Solution
S SnaKeSisNG Commendable Aug 3, 2016 35 0 1,540 Aug 31, 2016 #4 NextGear : SnakeSisNG, none, your PSU should have everything you need. Unless you want to go with a custom theme. I'm going for a white theme Upvote 0 Downvote
N NextGear Commendable Jul 20, 2016 194 0 1,760 Aug 31, 2016 #5 SnakeSisNG, There tons of sellers on eBay that will custom your PSU cables for you ^_^ Upvote 0 Downvote
