What cables do i need to connect the LG GH24NS95 24x DVD Drive?
DarkDubzs-1337570
40
So i know that it uses a SATA interface, which means you use a SATA cable to connect it, the thing is that i dont know if it needs multiple SATA cables or two different ones to connect it? And are there different types of SATA cables? If so, can you please tell me or link a SATA cable type that i need for this part?
Yes it is the same thing. Connection to a SATA drive requires two cables. Power (the large one), and data (the small one).
so i dont need to buy any extra cables? i just bought a Corsair CX430M power supply, so does that include a cable that i can use to connect the dvd drive? Or will i need to buy another cable, like will the one included in the power supple be already needed for any other parts?
