What Cables do I need to hook up a hard drive?
You need a Sata data cable and also a sata power cable (which is on your PSU). Most likely your case came with a couple and the power cables are part of your PSU
Yeah they will work flawlessly, I would buy extra just incase one breaks or you need to get data off of a laptop drive for your friend ect.
Normally your PSU (Power Supply) will have the power connector for the HDD and SDD.
If you need more:
Molex to Power SATA x2: Y-Cable
Power SATA to Power SATA x2: Y-Cable
SATA Cable:
Make sure they say at least 6gbps
For asthetics look for a color to match your build. This is just user preference
Always get more length than needed, you don't want to fall short. You can always store the excess in cable management space in your case
