W WhatAreYouLookingAt Commendable Apr 30, 2016 104 0 1,680 Jun 10, 2016 #1 I just want to play Halo 2 on medium or high settings!
Solution W W william p Jun 18, 2016 http://www.cpu-world.com/Compare/590/Intel_Core_2_Duo_E4400_vs_Intel_Core_2_Duo_E6700.html See if your motherboard supports this. Might require BIOS flash. How much RAM do you have, 32 bit or 64 bit Operating system, and what resolution will you be playing at?
SoNic67 Distinguished Jun 9, 2012 531 5 19,415 Jun 10, 2016 #2 Any video card you can get that has more than 256MB of memory A GT730 would be too nice for that game. Upvote -1 Downvote
dextermat Splendid Sep 21, 2007 4,956 0 24,960 Jun 10, 2016 #3 I recommend at least a x50 (550, 650.... for gaming) Upvote 1 Downvote
W weberdarren97 Glorious Aug 10, 2015 8,137 6 45,615 Jun 10, 2016 #4 MERGED QUESTION Question from WhatAreYouLookingAt : "What card is best for a Core 2 Duo E4400?" WhatAreYouLookingAt : I want to play Halo 2 on medium or high settings! Maybe some other games like Resident Evil 5. I would suggest the AMD R7 370 http://pcpartpicker.com/products/video-card/#c=309 Upvote 0 Downvote
W william p Splendid Sep 22, 2010 3,788 100 30,340 Jun 18, 2016 Solution #5 http://www.cpu-world.com/Compare/590/Intel_Core_2_Duo_E4400_vs_Intel_Core_2_Duo_E6700.html See if your motherboard supports this. Might require BIOS flash. How much RAM do you have, 32 bit or 64 bit Operating system, and what resolution will you be playing at? Upvote 0 Downvote Solution
