H hornsan1 Distinguished Oct 2, 2011 30 0 18,530 Oct 18, 2011 #1 Im looking to run three 23' monitors at 1080p and handle any game at the highest settings. What kind of cards or card will I be needing. I prefer nvidea evga cards. Money in this case is no object. Nor is space. Thanks
Solution inzone Oct 18, 2011 eric8705 : this is probably what youre looking for: http://www.eio.com/p-35631-evga-03g-p3-1584-ar-geforce-gtx-580-fermi-3072mb-384-bit-gddr5-pci-express-20-x16-hdcp-ready-sli-support-video-card.aspx if budget and space is not an issue for you then that card should be just perfect for you. make sure to get a PSU powerful enough to run the system. even bigger if you ever decide on SLI-ing it $80 cheaper at Newegg and for 3 monitors you need two.
E eric8705 Distinguished Aug 10, 2011 45 0 18,540 Oct 18, 2011 #2 this is probably what youre looking for: http://www.eio.com/p-35631-evga-03g-p3-1584-ar-geforce-gtx-580-fermi-3072mb-384-bit-gddr5-pci-express-20-x16-hdcp-ready-sli-support-video-card.aspx if budget and space is not an issue for you then that card should be just perfect for you. make sure to get a PSU powerful enough to run the system. even bigger if you ever decide on SLI-ing it Upvote 0 Downvote
inzone Champion Mar 12, 2011 14,971 1 51,960 Oct 18, 2011 #3 Well if money is no object then get two of these; EVGA 03G-P3-1584-AR GeForce GTX 580 (Fermi) 3072MB 384-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card http://www.newegg.com/Product/Product.aspx?Item=N82E16814130655 If you can catch them at Newegg or someplace else in stock get two of these; EVGA 03G-P3-1588-AR GeForce GTX 580 (Fermi) Classified 3072MB 384-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card http://www.newegg.com/Product/Product.aspx?Item=N82E16814130732 Upvote 0 Downvote
inzone Champion Mar 12, 2011 14,971 1 51,960 Oct 18, 2011 Solution #4 eric8705 : this is probably what youre looking for: http://www.eio.com/p-35631-evga-03g-p3-1584-ar-geforce-gtx-580-fermi-3072mb-384-bit-gddr5-pci-express-20-x16-hdcp-ready-sli-support-video-card.aspx if budget and space is not an issue for you then that card should be just perfect for you. make sure to get a PSU powerful enough to run the system. even bigger if you ever decide on SLI-ing it $80 cheaper at Newegg and for 3 monitors you need two. Upvote 0 Downvote Solution
H hornsan1 Distinguished Oct 2, 2011 30 0 18,530 Oct 28, 2011 #5 Best answer selected by Hornsan1. Upvote 0 Downvote
