what case and cooling?
ben77
Hiya all, this is what im going to put together:
-MSI z97 gamer 5
-i7-4790k
-MSI gtx 970
-1tb 7200rpm HD
NEED HELP With the following:
1. what power supply if I am planning to do some OC'ing in the future? (under $75)
2. what cooling system if I am planning to do some OC'ing in the future? ( I have seen hyper evo 212, and h100i but I am open to any suggestions!)(under $90)
3. What case to fit all this with the cooling system in? (the cheaper the better)
Thank you all very much in advance for your help!
The components in my sig below would be one way to go... The H60 cooler is a step above the 212 EVO for cooling. The H100i a step above that. But with a $90 budget, I'd go with the H60 or 212 EVO.
As for the $75 or less PSU, you won't need much wattage as long as you stay with the power sipping GTX 970. This is one option: http://www.newegg.com/Product/Product.aspx?Item=N82E16817371044
