What case and do i need case fans?
Callum McKay
45
What case should i get? Not looking to spend a lot of money.
corsair 230t
corsair 200r
cooler master n600
nzxt h230
Would i need any extra case fans with this setup and one of the above fans? http://nz.pcpartpicker.com/p/Z3VwZL
has anyone had problems with any of these cases? feel free to suggest new cases or different pc parts to my setup if you find a mistake!
Leds and windows do not bother me
Thanks in advance!!
Ok cool but would you have any experience with these cases?
you dont get any problems with cases hardly so you dont need to worry
Regarding the comments above - the antec hcg's are tip-top quality supplies - all I would say is if you're considering big over clocks onbyour CPU in the future then an extra $10 on the 620w model will give you huge amounts of headroom which is never a bad thing.
The 520 will be fine but for that little extra expenditure the 620 would be worth it IMO.
Thanks! will get that one instead!
