Isokolon :
Looking at your build, I'm pretty sure you don't need a 1000W PSU.
650W should suffice and will be easier on your budget. I suggest going for the G3 instead of the G2 though.
Furthermore I would drop the sound card
It doesn't do much than blocking airflow and using up PCI lanes. A 48$ sound card won't be much better than your onboard solution and if you got some serious pro headphones for 250+$ you don't want to use an dedicated internal sound card anyway but go for a external DAC+AMP solution.
Also, do you burn a lot of Bluerays? Because 120$ for an optical drive in 2017 is excessive, especially if you don't have a SSD drive.
There are of course circumstances that make such a drive necessary but otherwise it's just a huge waste of money that could be reinvested smarter somewhere else
Which brings me to my next point: get a SSD. Crucial's MX300 is nice, as is Samsung's 850 Evo. 250-300GB for Windows and some of your favourite applications should suffice next to your HDD
As for fans the case comes with all the necessary fans preinstalled and they are premium quality Phanteks fans (best out there)
Thanks for the suggestions! Definitely making changes to my list! I did the 1000W PSU because a friend of mine said to go with 1000W, which I thought was excessive as well, but since I'm a novice, I said to myself, "hey, he knows better than me, so I'll listen to him."
coughs I happened to have it at 650W before, I guess I can tell him that I told him so. coughs
I do happen to burn a lot of Blu-rays, yes! CD's, DVD's, and tons of Blu-rays for backups in case I lose the original disc, which has happened too many times to count, and I have quite the extensive of movie collection, so yes, it is necessary. I burn music, and even files on CD's and DVD's as a makeshift flash drive, not to mention I usually watch movies on my PC via disc. Plus, well, some of the software I have is installed via disc, so. $120 is a lot for an optical drive, hopefully I can find one cheaper of course, but if I can't, it is something that I would I guess be fine with doing. I was looking at SSD's, but I didn't know what brand was really good yet and how many GB's to even go with for an SSD, so I was holding off on it, but since you told me, you pretty much answered my prayers there.
Thanks a lot for your suggestions, it really helped a newbie like me out! Thank you!
