What Case will fit EVERYTHING?
Quick check on cases under $100 that I've dealt with personally and like or have seen good reviews.
Cooler Master HAF 912 USB3.0 - 175mm clearance. So "should" fit.
NZXT H440 - 180mm clearance.
Fractal Design Define S - 180mm clearance.
NZXT Source 530 - 183mm clearance.
What's your budget? Affordable is fairly subjective.
With the cooler you've chosen, its going to be a bit harder to do in an cheapish case. You'll need a minimum of 175mm of CPU cooler clearance on the case. 165mm for the cooler, and another 10mm for the fan adjustment that'll be needed for the RAM you have.
I'm now definitely considering the NZXT H440, as you say it will fit all that I need. I have to consider for the motherboard too right? I think this case will fit all the things but i really don't want to mess this up as it will be my first time buying a PC.
Yeah the H440 will fit it all no problem. I've built up in that case before and its a nice one. If you do decide to go that route, and use their 2.5 drive setup you'll want to pick up a SATA extender cable like one of these.
http://www.newegg.com/Product/Product.aspx?Item=N82E16812400046&cm_re=sata_extension_cable-_-12-400-046-_-Product
The way that case mounts the drive in, using the end of a normal SATA power cable lifts the back of the drive just enough to put a strain on the SATA connector due to the right angle of the power cable connector. Not a huge strain but for me putting any undo stress on that part of a drive is a bad idea.
The only real issue your build has is that cooler, otherwise you could put it all in just about any normal Mid ATX case. As someone who has a NH-D15 I do have to ask, is that cooler worth changing your case over? Don't get me wrong I love it, and its a great quiet cooler, but it is a huge and heavy beast and often makes builders change what they want to do.
EVERYTHING?
(CaseLabs Magnum TX10.)
True true, it is a monstrous cooler but I'm getting it so that I will never have an issue when it comes to worrying about anything overheating when over clocked. I'm going to be primarily gaming and so if I buy a nice graphics card, I would prefer there to not be any reason for it to be at a dangerous Celcius
Nope solid reason, its the reason I picked up mine. Just seen some people on here go for it not knowing what they're getting in to with it. Rock on then, you should have a solid system when you're done.
