What cause this problem? BSOD 0x124
divine123
23
Hi I got this problem
I dont know if it is because the video card or it is something else.
someone told me that lack of memory (RAM) having a Nvidia Galaxy Geforce GTX260 could have possibly got the problem. though I'm still not sure, I'm having different errors, other errors i dont have the dump files and i wish i could attach a dump file in this forum so you guys can easily help me.
anyways heres my crappy computer specs
Core2duo e4500 2.20ghz
2 sticks of 1 GB RAM DDR2 667 ( so thats 2 GB of ram intalled)
nvidia galaxy geforce gtx 260+
Stop 0x124 is a hardware error
If you are overclocking try resetting your processor to standard settings and see if that helps.
If you continue to get BSOD here are some more things you may want to consider.
This is usually heat related, defective hardware, memory or even processor though it is"possible" that it is driver related (rare).
Stop 0x124 - what it means and what to try
Synopsis:
A "stop 0x124" is fundamentally different to many other types of bluescreens because it stems from a hardware complaint.
Stop 0x124 minidumps contain very little practical information, and it is therefore necessary to approach the problem as a case of hardware in an unknown state of distress.
Generic "Stop 0x124" Troubleshooting Strategy:
1) Ensure that none of the hardware components are overclocked. Hardware that is driven beyond its design specifications - by overclocking - can malfunction in unpredictable ways.
2) Ensure that the machine is adequately cooled.
If there is any doubt, open up the side of the PC case (be mindful of any relevant warranty conditions!) and point a mains fan squarely at the motherboard. That will rule out most (lack of) cooling issues.
3) Update all hardware-related drivers: video, sound, RAID (if any), NIC... anything that interacts with a piece of hardware.
It is good practice to run the latest drivers anyway.
4) Update the motherboard BIOS according to the manufacturer's instructions.
Their website should provide detailed instructions as to the brand and model-specific procedure.
5) Rarely, bugs in the OS may cause "false positive" 0x124 events where the hardware wasn't complaining but Windows thought otherwise (because of the bug).
At the time of writing, Windows 7 is not known to suffer from any such defects, but it is nevertheless important to always keep Windows itself updated.
6) Attempt to (stress) test those hardware components which can be put through their paces artificially.
The most obvious examples are the RAM and HDD(s).
For the RAM, use the in-built memory diagnostics (run MDSCHED) or the 3rd-party memtest86 utility to run many hours worth of testing.
For hard drives, check whether CHKDSK /R finds any problems on the drive(s), notably "bad sectors".
Unreliable RAM, in particular, is deadly as far as software is concerned, and anything other than a 100% clear memory test result is cause for concern. Unfortunately, even a 100% clear result from the diagnostics utilities does not guarantee that the RAM is free from defects - only that none were encountered during the test passes.
7) As the last of the non-invasive troubleshooting steps, perform a "vanilla" reinstallation of Windows: just the OS itself without any additional applications, games, utilities, updates, or new drivers - NOTHING AT ALL that is not sourced from the Windows 7 disc.
Should that fail to mitigate the 0x124 problem, jump to the next steps.
If you run the "vanilla" installation long enough to convince yourself that not a single 0x124 crash has occurred, start installing updates and applications slowly, always pausing between successive additions long enough to get a feel for whether the machine is still free from 0x124 crashes.
Should the crashing resume, obviously the very last software addition(s) may be somehow linked to the root cause.
If stop 0x124 errors persist despite the steps above, and the harware is under warranty, consider returning it and requesting a replacement which does not suffer periodic MCE events.
Be aware that attempting the subsequent harware troubleshooting steps may, in some cases, void your warranty:
8) Clean and carefully remove any dust from the inside of the machine.
Reseat all connectors and memory modules.
Use a can of compressed air to clean out the RAM DIMM sockets as much as possible.
9) If all else fails, start removing items of hardware one-by-one in the hope that the culprit is something non-essential which can be removed.
Obviously, this type of testing is a lot easier if you've got access to equivalent components in order to perform swaps.
Should you find yourself in the situation of having performed all of the steps above without a resolution of the symptom, unfortunately the most likely reason is because the error message is literally correct - something is fundamentally wrong with the machine's hardware.
could the GPU possibly cause the problem or not? And I'm not overclocking my GPU though my GPU is Overclocked when I bought it. I just dont know what is the standard settings for the GTX 260
hi I just got a little bit of answer of whats goin on with the situation. I think the problem is my motherboard. hmm, its gradually having different issues, like first the onboard lan just pass out and not working anymore and theres a lot of times where in I got 2 sticks of good ram and the motherboard cant detect it so I need to restart it a couple of times before I can get it working. though I already updated the bios but the problem still occur. I dont know if its also the power supply, I only got 450w psu. goin to check for new motherboard and I'll update if it solves the problem.
Okay 😉
