What computer case will the following components fit in?
Mr_Raisin
4
CPU - AMD FX-6300
MOBO - ASUS M5A78L-M/USB3
GPU - EVGA GTX 960
RAM - Crucial Ballistix 8GB
HDD - Seagate 1 TB
PSU - EVGA 500W 80PLUS/Corsair VS550 550W (one or the other possibly, unless you have another suggestion because I know they're both quite cheap).
The main problem is I need a suggestion of a case that the above components will fit in.
I am open to changes of these components as long as they're not to expensive. Also, will this potential PC combination make a good gaming PC?
I'm on a budget of about $1000 NZD ($683.79 USD).
Sorry, with the power supplies, it's one of the 2, not worried what one but you can suggest
and
With the case, I need a suggestion that the components will fit in because I'm having trouble finding a suitable case
