A Ajays1906 Prominent May 24, 2017 3 0 510 May 24, 2017 #1 Connecting SPDIF out from NEXBOX A95X to optical in of Onkyo HT3100
A americanaudiophile Titan Aug 27, 2008 13,663 0 101,360 May 25, 2017 #2 It's hard to tell whether the SPDIF output of the Netbox is optical or coax. If you don't see any metal contacts inside the hole it's probably using a portable optical jack and you need a cable like this one. https://www.amazon.com/dp/B010W3F0TA/ref=asc_df_B010W3F0TA4999085/?tag=hyprod-20&creative=394997&creativeASIN=B010W3F0TA&linkCode=df0&hvadid=193992629021&hvpos=1o3&hvnetw=g&hvrand=15986202243727773228&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9004455&hvtargid=pla-313747035729 If there are metal contacts then it's a coax digital connector and you need a 75ohm coax cable with 3.5mm at the box and RCA at the receiver. https://www.walmart.com/ip/L21-3-RCA-Digital-Coaxial-Cable-with-3-5mm-to-RCA-Connector-for-X3-II-X5-II-and-X7-Audio-Players/579885181?wmlspartner=wlpa&selectedSellerId=6907&adid=22222222227082744211&wmlspartner=wmtlabs&wl0=&wl1=g&wl2=c&wl3=196360012004&wl4=pla-315702466471&wl5=9004455&wl6=&wl7=&wl8=&wl9=pla&wl10=115781154&wl11=online&wl12=579885181&wl13=&veh=sem Most likely it's optical. Upvote 0 Downvote
A Ajays1906 Prominent May 24, 2017 3 0 510 May 26, 2017 #3 americanaudiophile : It's hard to tell whether the SPDIF output of the Netbox is optical or coax. If you don't see any metal contacts inside the hole it's probably using a portable optical jack and you need a cable like this one. https://www.amazon.com/dp/B010W3F0TA/ref=asc_df_B010W3F0TA4999085/?tag=hyprod-20&creative=394997&creativeASIN=B010W3F0TA&linkCode=df0&hvadid=193992629021&hvpos=1o3&hvnetw=g&hvrand=15986202243727773228&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9004455&hvtargid=pla-313747035729 If there are metal contacts then it's a coax digital connector and you need a 75ohm coax cable with 3.5mm at the box and RCA at the receiver. https://www.walmart.com/ip/L21-3-RCA-Digital-Coaxial-Cable-with-3-5mm-to-RCA-Connector-for-X3-II-X5-II-and-X7-Audio-Players/579885181?wmlspartner=wlpa&selectedSellerId=6907&adid=22222222227082744211&wmlspartner=wmtlabs&wl0=&wl1=g&wl2=c&wl3=196360012004&wl4=pla-315702466471&wl5=9004455&wl6=&wl7=&wl8=&wl9=pla&wl10=115781154&wl11=online&wl12=579885181&wl13=&veh=sem Most likely it's optical. Upvote 0 Downvote
A Ajays1906 Prominent May 24, 2017 3 0 510 May 26, 2017 #4 Thanks for help, the connection on the Nextbox A95X doe not have a metal connector. There a female port , mentioned as SPDIF. Shud I share a photo ? Upvote 0 Downvote
