So I know that when it comes to the CPU 4-pin header the PWM signal is changed depending on the CPU's temperature. But there are more 4-pin fan headers on the motherboard which use PWM apart from the CPU dedicated ones. I have found that in most of them these are usually called Sys_Fan1, Sys_Fan2 etc. So this is my question: what controls the PWM signal on these fans? Is it the temperature of another component or is it something you can manually set up in the motherboard's bios? If I were to plug a 4 pin fan in one of those headers, what would it take for the PWM signal to change?
The pic below has 3 of these "extra" 4-pin fan headers
Thank you for the help!
