What Cooler for case
Aaron Connor
52
I am building a new system and need some advice?
CPU: 4790K Devils
Case: Corsair Carbide Series 200R Compact Mid Tower
I can't find a Sub £40 cooler that will fit the case.
I was going to get the RR-212E-16PK-R1 - Cooler Master Hyper 212 EVO, 4 but I do not think it will fit the case.
I wasn't going to say it, but a different case is what I was actually thinking.
I doubt the Coolermaster will fit. My Coolermaster 430 elite is 8.3" wide and the Hyper 212 Evo has about 1/4 inch of room between it and the plexiglass and the Corsair case is 7.5" wide. You need a cooler below about 140mm in height, the Coolermaster is 159mm.
Any good suggestions?
There aren't a lot of good choices that small. Pretty much everything with a 120mm fan is too tall. This seems pretty solid though and has good reviews.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118003
