Question What cooler for Ryzen 7 5800x?
matacar
98
I am upgrading my pc, changing almost all components except the SSD and PSU.
I am looking for what cooler to buy for Ryzen 7 5800x.
My goal is gaming and streaming, I don't plan on overclocking anything.
Do you have any suggestions? Nothing crazy expensive, an air cooler if possible.
sonofjesse
329
64
4,790
8
Fuma 2. it's 60 instead of 100. Great value and very close to the Noctua (go look at the videos).
Since cryorig is hard to get right now, FUMA 2 is now my go too high performance affordable cooler!!!
I have seen a lot of Noctua suggestions like the noctua nh-d15.
What is your opinion on Fuma 2? It is similar to Noctua and I can save like 40 dollars.
I'd say it's worth a shot can't go wrong giving new things a go seems like it should be decent and from things I have heard from people and read it's just under the equivalence of a noctua. Just as good using liquid medal thermal compound
Phaaze88
Polypheme
Ambassador
@matacar
I'm not sure you'll even notice a large difference between any of these dual tower air coolers.
It looks like, at the worst of times, this cpu doesn't pull more than ~140w:
https://www.tomshardware.com/reviews/amd-ryzen-7-5800x-zen-3-review/2
o https://www.tomshardware.com/reviews/amd-ryzen-7-5800x-zen-3-review/3
In that regard, something like a NH-U14S, U12A, or Mugen 5 Rev B. should be enough, and more efficient than a big dual tower, because the big dual tower's capacity isn't being reached by any means.
The reason the 5800X is so 'hot' is before you even put any kind of cooler on it to begin with:
-the IHS isn't efficient at transferring the heat of the Multi Chip Module design, so some of the heat is 'lost' in the socket, before it can be transferred up through the heatspreader/paste/cpu cooler.
-the higher thermal density of TSMC's 7nm process.
-Ryzen 5000 has an even more aggressive turbo boost algorithm than previous Ryzen 3000 line. The latter would stop trying to push higher clocks around 80C. 5000 doesn't stop until 90-95C... if it hasn't run into the PPT limit first.
-The 5800X is clock binned, but not voltage binned. Crazy how the 5900X and 5950X can run cooler than it...
Undervolting, or a negative voltage offset would likely help this cpu more than just getting a dual tower. Well, nothing's stopping you from doing both...
Reactions: white.a.drew
tkp
27
I have the 5800x and Dark Rock Pro 4. I picked it for its looks, I was going for a black theme. I was pleasantly surprised with how good it really was. When testing it with prime95 I topped at around 65. The fans never kicked up enough to be very noticable either. First time I ever had a dual tower cooler.
matacar
98
@matacar
This is some very good information. Thank you so very much. However, I don't want to risk anything or pull any punches. I also don't want to buy the most premium stuff like crazy liquid cooling. I still have a limited budget.
If you don't mind, I was planning on going with Cooler Master Masterbox K501L PC case. I am not sure if everything will fit or will it have good airflow. Do you have any case recommendations for 50-60 dollars if possible?
matacar
98
What kind of case do you have? Do you have any case recommendations for 50-60 dollars if possible?
matacar
98
I keep my NH-D15S single fan at 1100 RPM max. Keeps my 12 core 3900X at 65C under most loads, except for Cinebench which brings it to ~75C.
As for the Dark Rock Pro 4, the installation system on that thing is god awful. Noctua's SecuFirm is still the best.
Interesting. Do you have any case recommendations for 50-60 dollars if possible?
tkp
27
I went with the Meshify C, but I added 2 140mm be quiet fans in the front.
It is a bit more than the $60. I am sure others will have better recommendations than me. Still learning here.
