[SOLVED] What cpu dose my motherboard support?need help pleas
Rastafare
16
Hii thx for viewing this tread well i bought an Asus H110-I /M32CD4 /DP_MB motherboard and i wanna upgrade the cpu but i dk which cpu i can get coz i know there are compatable and non compitable so which one are supported on my motherboard my current cpu is i3 6100
All H110 boards support same cpus.
Initially they support 6th gen Intel core cpus. With appropriate BIOS update they support 7th gen also.
i5-6400 is definitely supported.
Did you check cpu suppport list from motherboard manufacturer support site?
Sorry for late response ,,i did but that dosent look anytin like my motherbord its the same asus but let me send a pic of my mother bord n see i wanna upgrade to an i5 6400 but iam nat shure if its compatibe thats y i need help heres my motherbord https://images.app.goo.gl/fZZd3Z4hPoe6av1b6
