ive been looking for a way to do this for a while and i still dont quite understand 🙁
i know that you need a reservoir, pump, radiator (+ fans), tubing and fittings but i dont exactly know what size reservoir i need, what pump works for a pump/reservoir combo so it takes up the least space in my case, a perfectly large radiator and which fittings to get for the tubing.
im wanting to be going with hard tubing also.
I am going to be getting my cooling blocks for the GPU and the CPU from EK but need to know what size reservoir i need to cool all of the components (which will be slightly overclocked) the CPU will run at about 4.5ghz - 4.7ghz and the GPU will be running at around 2000mhz.
i have an i7 6700K, a GTX 1080 and my case is a corsair 750D airflow edition.
if you guys could help, that would be amazing as i dont know where else to receive advise/help.
