What do I need to have 4 static IPs using a wireless router from DSL
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Century link sold me a wireless router, but now there support says that it won't work with 4 static ip's what kind of wireless router should I buy.
Have you tried setting static IPs and if so, how and what happened? I believe Support has it wrong and may have thought you were seeking a static IP from them. If all you want is static IPs within your own network, it's nothing to do with them and everything to do with the settings you apply in TCP/IP Properties.
Take the address of the router as the Default Gateway and that should be in the router's manual. If it is, for example, 192.168.0.1, click on the Alternative Configuration tab and set the IP for computer #1 as 192.168.0.2, #2 as 192.168.0.3, etc. Subnet mask will be 255.255.255.0 but you'll probably only type in 25 and the rest will auto-complete.
[/#000ff]
