Hello
I have a situation about the SSD reported at:
* After apt upgrade - Failed to start VirtualBox Linux Kernel - I/O error, dev sda
I did do a research in the web and is suggested work with the smartctl command and GSMartControl GUI
First the SSD partitions for a better understanding
/dev/sda1
/dev/sda2
As follows the reports:
sudo smartctl -H /dev/sda1
sudo smartctl -H /dev/sda2
So far all seem fine
sudo smartctl -a /dev/sda1
sudo smartctl -a /dev/sda2
sudo smartctl -x /dev/sda1
sudo smartctl -x /dev/sda2
Sorry for the long outputs
I am not an expert about this data report, so I am providing detailed information for you. According with the long output, Should I assume the SSD is passing away? So far my main concern is the following:
and
Note: Pls, if you find some important point in the result let me know
/dev/sda1
/dev/sda2
Bash:
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-6.5.0-35-generic] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
Bash:
Bash:
=== START OF INFORMATION SECTION ===
Device Model: WD Blue SA510 2.5 1000GB
Serial Number: 22196N807187
LU WWN Device Id: 5 001b44 8b08f5266
Firmware Version: 52008100
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
TRIM Command: Available, deterministic
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-4, ACS-2 T13/2015-D revision 3
SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sun Jun 9 10:45:21 2024 -05
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 0) seconds.
capabilities: (0x71) SMART execute Offline immediate.
No Auto Offline data collection support.
Suspend Offline collection upon new
command.
No Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 10) minutes.
Conveyance self-test routine
SMART Attributes Data Structure revision number: 0
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
5 Reallocated_Sector_Ct 0x0032 100 100 010 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 2
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 1057
165 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 98173724
166 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
167 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 17
168 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 1
169 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 236
170 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
171 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
172 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
173 Unknown_Attribute 0x0032 100 100 005 Old_age Always - 0
174 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 742
184 End-to-End_Error 0x0032 100 100 097 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
194 Temperature_Celsius 0x0022 100 100 014 Old_age Always - 32 (Min/Max 17/39)
199 UDMA_CRC_Error_Count 0x0032 100 100 000 Old_age Always - 0
230 Unknown_SSD_Attribute 0x0032 100 100 000 Old_age Always - 1524713390435
232 Available_Reservd_Space 0x0033 100 100 004 Pre-fail Always - 94
233 Media_Wearout_Indicator 0x0032 100 100 000 Old_age Always - 0
234 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 16429
241 Total_LBAs_Written 0x0030 253 253 000 Old_age Offline - 530
242 Total_LBAs_Read 0x0030 253 253 000 Old_age Offline - 382
244 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
Warning! SMART ATA Error Log Structure error: invalid SMART checksum.
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Completed without error 00% 2 -
# 2 Short offline Completed without error 00% 0 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Bash:
Local Time is: Sun Jun 9 10:47:52 2024 -05
was never started.
been run.
command.
power-saving mode.
165 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 98632477
194 Temperature_Celsius 0x0022 100 100 014 Old_age Always - 33 (Min/Max 17/39)
234 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 16467
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Bash:
Local Time is: Sun Jun 9 10:49:42 2024 -05
AAM feature is: Unavailable
APM level is: 254 (maximum performance)
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Unavailable
was never started.
been run.
command.
power-saving mode.
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
5 Reallocated_Sector_Ct -O--CK 100 100 010 - 0
9 Power_On_Hours -O--CK 100 100 000 - 2
12 Power_Cycle_Count -O--CK 100 100 000 - 1057
165 Unknown_Attribute -O--CK 100 100 000 - 99025695
166 Unknown_Attribute -O--CK 100 100 000 - 0
167 Unknown_Attribute -O--CK 100 100 000 - 17
168 Unknown_Attribute -O--CK 100 100 000 - 1
169 Unknown_Attribute -O--CK 100 100 000 - 236
170 Unknown_Attribute -O--CK 100 100 000 - 0
171 Unknown_Attribute -O--CK 100 100 000 - 0
172 Unknown_Attribute -O--CK 100 100 000 - 0
173 Unknown_Attribute -O--CK 100 100 005 - 0
174 Unknown_Attribute -O--CK 100 100 000 - 742
184 End-to-End_Error -O--CK 100 100 097 - 0
187 Reported_Uncorrect -O--CK 100 100 000 - 0
188 Command_Timeout -O--CK 100 100 000 - 0
194 Temperature_Celsius -O---K 100 100 014 - 34 (Min/Max 17/39)
199 UDMA_CRC_Error_Count -O--CK 100 100 000 - 0
230 Unknown_SSD_Attribute -O--CK 100 100 000 - 1524713390435
232 Available_Reservd_Space PO--CK 100 100 004 - 94
233 Media_Wearout_Indicator -O--CK 100 100 000 - 0
234 Unknown_Attribute -O--CK 100 100 000 - 16499
241 Total_LBAs_Written ----CK 253 253 000 - 530
242 Total_LBAs_Read ----CK 253 253 000 - 382
244 Unknown_Attribute -O--CK 100 100 000 - 0
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 1 Comprehensive SMART error log
0x03 GPL R/O 16 Ext. Comprehensive SMART error log
0x04 GPL,SL R/O 8 Device Statistics log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x09 SL R/W 1 Selective self-test log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xa0-0xa1 GPL,SL VS 1 Device vendor specific log
0xa2 GPL,SL VS 2 Device vendor specific log
0xa3-0xa7 GPL,SL VS 1 Device vendor specific log
0xde GPL,SL VS 1 Device vendor specific log
Warning! SMART Extended Comprehensive Error Log Structure error: invalid SMART checksum.
SMART Extended Comprehensive Error Log Version: 1 (16 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
SCT Commands not supported
Device Statistics (GP Log 0x04)
Page Offset Size Value Flags Description
0x01 ===== = = === == General Statistics (empty) ==
0x05 ===== = = === == Temperature Statistics (empty) ==
0x07 ===== = = === == Solid State Device Statistics (empty) ==
|||_ C monitored condition met
||__ D supports DSN
|___ N normalized value
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 2 0 Command failed due to ICRC error
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
0x0009 2 0 Transition from drive PhyRdy to drive PhyNRdy
0x000a 2 5 Device-to-host register FISes sent due to a COMRESET
0x000f 2 0 R_ERR response for host-to-device data FIS, CRC
0x0013 2 0 R_ERR response for host-to-device non-data FIS, non-CRC
Bash:
Local Time is: Sun Jun 9 10:51:02 2024 -05
was never started.
been run.
command.
power-saving mode.
165 Unknown_Attribute -O--CK 100 100 000 - 99287840
230 Unknown_SSD_Attribute -O--CK 100 100 000 - 2199023256064
234 Unknown_Attribute -O--CK 100 100 000 - 16521
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
||__ D supports DSN
Bash:
No Errors Logged
and
Bash:
No Errors Logged
