What does a perif cable go
gamboooooo
49
im building my computer and there is some perif cables, is it required to be connected if so where.
also there are a lot of extra cables that look the same, does ever cable need to be connected?
No, you just connect the cables the components need. I've read about people trying to connect every power cable to something, with the result of sparks, smoke and dead computer hardware. Read the manuals that came with your equipment about what to connect.
Hi,
Those cables are most likely to be your usb ports/audio connecxions and any other port that are in front of the computer.
You can look into your motherboard user guide to see where to plug them
