What does Cross fire do?
May 9, 2014
16
Hello guys i am thinking about using cross fire because i play some hardcore games, and the graphic card i have, just doesn't feel right for some of my games.
This is the graphic card i have right now?
http://www.cplonline.com.au/gigabyte-radeon-r9-270x-oc-4gd-with-bf4-bundle-gv-r927xoc-4gd-ga.html
Can you guys give me some graphic cards that might be good to cross fire with my card? or a new graphic card so i can use because the problem is when i run games, i put it on ultra, it is smooth but, it is not smooth enough and the graphics doesn't even look ultra and it doesn't feel 100% smooth.
Hmm can i cross fire with this graphic card?
http://www.cplonline.com.au/sapphire-radeon-r9-280x-toxic-edition-3gb-sa-r9280x-3gd5-toxic.html
It looks seems better than mine it has 6400 MHz Effective, but it only has 3gb memory?...
is the Mhz the more faster?
These are the two shops that live near me so i can go and buy them.
http://centrecom.com.au/
Two questions, if you please. What kind of system are you running it in (CPU, memory) and what games?
Also, you should consider getting a more powerful single card. Crossfire is a great invention, and they've gotten the pacing problems out, but a single card is simpler and should suck less power. Not saying not to Crossfire, just consider a new single card.
Which game are u running and ur graphic card is pretty good it can run.try enabling v-sync if u have an option
.and update the driver.there is one more fix for this prob.Press win+R key type msconfig go to services tab and disable event log and event manager.Hope it works.....U should have the sata cable so u can connect 2 graphic cards which i know and ur R9 270x is awesome u can run even the future games maxedd out @1080p..
