What does ctrl + alt + del do on bootup? help
Odetzz
Commendable
Sep 17, 2016
15
I have a clean install of windows 10 and If I do not press ctrl + alt + del on computer boot up (on the part where you can enter bios) Im getting this unusable computer with continuous flashing screen https://gyazo.com/1a8d852b1315e677c383aef1516a6057 <-- here's a showcase of it.
WHAT DOES CTRL ALT DEL DO ON BOOTUP? My computer only works if I press those on boot up.
I know that the problem is not from my psu. I have a new gpu which I bought a month ago and it started doing this, even after a clean windows install. It's not about the drivers either.
My motherboard is Asrock 970 pro3 r2.0 and gpu is gtx 1060 6gb.
HELP, Im getting sick of this, i've had this problem for over a month now...
IM SERIOUSLY THE ONLY ONE IN THE WORLD WITH THIS GOD DAMN PROBLEM
Odetzz
Commendable
Sep 17, 2016
15
fx 6300. Computer worked fine before installed my gtx 1060 a month ago. check out my latest post about the POST scan thing
