What does entry-level graphics card really mean?
JLH555
47
I have been told that the gtx 645 is a entry-level gpu, so I was wondering what that really means. Does that mean I can only play really old games? Does that mean I can play brand-new games at low settings? if you need a game to help explain, Rome 2 would work
But I have seen youtube videos of BF3 being played at a pretty high-quality. Of course they could be lying, but I don't see why they would. is it really that bad? Of course it isn't a "good" card, but is it really trash?
It really just means the cheapest / lowest spec card you can get away with for modern gaming at low-medium settings.
However you can frequently cross off the latest gpu killer game off your birthday list, like crysis 3 for example.
Both AMD and nVIDA tend to adjust their offerings frequently sometimes renaming cards to fill that exact market.
So what about a game like Bf3 at medium? would a entry-level card be able to do that (specifically the gtx 645)?
What would it be like, out of curiosity, to play crisis 3 with a 645? I assume it would be able to do SOMETHING, right?
I dont play battlefield so I cant tell you. I wouldnt want to run crysis 3 on anything less than a 7850 with a pretty strong cpu personally.
If a 645 was paired up with a good cpu (which is unlikely in a budget system an entry lvl card would be used in) I'm sure it could hover around 30fps on medium. You would have to keep the AA off (or very low).
I'm sure you can look up some youtube videos on games you are interested in, with the cards you are thinking of.
if it had a i5 4440 with it, what could that do?
If you took all of the games that are out right now, would i be able to play most at a PLAYABLE level with the exception of a few like Crysis 3 and Bf 4 ?
