What does offline mean for a printer
  • Thread starter Thread starter Guest
  • Start date Start date
It usually means you should press a button on the printer to bring it on-line. If there are LED indicators one should illuminate or change from red to green.
If there are no switches, or nothing changes when you press them it may indicate a connection problem. Check cable between printer and computer.
